SF32LB52-LCHSPI-ULP
Board sf32lb52-lchspi-ulp is based on the 立创·黄山派 development board (SF32LB52-黄山派), which is designed as a smart watch / smart band reference design, and
has module SF32LB52X-MOD-1-N16R8 on the board.
The module integrates SoC SF32LB525UC6 with 16MB QSPI-NOR Flash and 8MB OPI-PSRAM.
Main on-board resources:
1.85-inch 390x450 QSPI AMOLED display (driver IC CO5300) with capacitive touch panel
Audio: on-board MEMS microphone and Class-D audio power amplifier, with a GH-1.25mm connector for an external speaker (up to 3W/4Ω or 2W/8Ω)
Keys: KEY1 power key (PA34, long-press to reset) and KEY2 function key (PA43)
USB Type-C to UART for program download and debug; SPI interface TF card slot
RGB LED, motor driver, 6-axis IMU (LSM6DS3TR-C), 3-axis magnetometer (MMC5603NJ) and ambient light sensor (LTR-303ALS-01)
30-pin 1.27mm expansion header exposing GPIOs, power rails and debug UART
For detailed hardware information (microphone / speaker wiring, GPIO assignment, connector pin definitions, power supply options, etc.), please refer to the SF32LB52-黄山派 board user guide.
