SF32LB57-EPD_N16R16
sf32lb57-epd_n16r16 supports the SF32LB57-DevKit-EPD_MB_V1.0 e-paper development board. It uses an SF32LB57GYD7N6 chip with 16 MB NOR Flash and 16 MB PSRAM.
On-board hardware
Hardware |
Interface and pins |
E0470A03 e-paper display |
4.7 inches, 684 × 1216 in portrait orientation; LCDC1 8-bit TCON interface |
TPS65185 display power |
I2C1, address 0x68; WAKEUP PA42, PWRCOM PA43, PWRUP PA44, PGOOD PA52 |
FT5446U touch |
I2C2, address 0x38; interrupt PA3, reset PA4, power PA5 |
AW99703 frontlight |
I2C1, address 0x36; enable PA53 |
Wi-Fi |
SDMMC1: CLK PA14, CMD PA15, D0–D3 PA16/PA17/PA12/PA13; power PA8, PDN PA9 |
TF card |
SDMMC2: CLK PA47, CMD PA48, D0–D3 PA49/PA50/PA45/PA46; detection PA51 |
NS4150B amplifier |
Enable PA54 |
Digital microphone |
PDM1: CLK PA55, DATA PA56; power PA57 |
Buttons |
PA34 interrupt; ADC channel 6 distinguishes three buttons |
Power detection |
USB presence PA6, charging status PA7, battery voltage ADC channel 11 |
I2C1 uses PA20/PA21 for SCL/SDA. I2C2 uses PA1/PA2.
Display signals: SDCLK PA24, SDLE PA25, SDOE PA26, SDSTL PA27, SDAT0–SDAT7 PA28/PA29/PA30/PA31/PA32/PA33/PA37/PA38, GMODE PA39, GDCLK PA40, and GDSP PA41.
Build
Load the build environment from the SDK root, then build Hello World:
. ./export.ps1
cd example/get-started/hello_world/rtt/project
scons --board=sf32lb57-epd_n16r16_hcpu -j8
The HCPU configuration selects the SDK E0470A03 display driver and FT5446U touch driver by default. The acpu directory provides the board configuration for ACPU child projects in SDK multicore builds.
Projects can enable Wi-Fi and TF card support as needed. SDMMC1 uses SDIO mode; board initialization enables the PA8 supply, and the Wi-Fi driver controls PDN on PA9. SDMMC2 uses SD card mode. Call BSP_Microphone_PowerOn() before recording with the digital microphone and BSP_Microphone_PowerOff() when finished. The power-on function must run in thread context.
Display waveform
The board uses a binary waveform table. With the default ptab.json, program the SDK file customer/peripherals/display/epd_e0470a03/waveform/epd_waveform.bin at 0x12CE8000. The wave_table partition reserves 256 KiB.
When a project overrides the partition table, use the generated CUSTOM_EPD_WAVE_TABLE_START_ADDR as the waveform programming address.
